Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-02-2005, 01:46 AM
drummerfor440 drummerfor440 is offline
90 caprice 350 5.7 need help fast
ok here is the deal the origonal engine in the car was a 305 5.0 tbi but at the time it was going down hill fast, so i went out to buy an new 305 ( $2000 or so) for it but instead the place i had purchased it from got it mixed up and gave me a 350 lt1 engine ($4000) for a corvette (aluminum heads and god knows what cam), needless to say i put it in and kept the engine "ha ha ha" after switching everything in the car over to match the 350 engine (computer, sensors etc...) i am having a problem with an error code. i looked it up and its saying that the esc or something like that isnt functioning correctly. so i swaped that with another brand new one and i still get the code. it only happens when i hit the breaks then hit the gas right away to take off. after the check engine light comes on the car looses all h.p. and is slow as all hell ( as if the timing was being retarted by the computer ). i went ahead and checked for vacume leaks and there are none. anyone have any suggestions? the only thing that is stock on that car is the body, frame, and exaust.
Old 10-02-2005, 08:25 AM
CD Smalley CD Smalley is offline
Re: 90 caprice 350 5.7 need help fast
What is the specific code that you are getting....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-03-2005, 11:23 AM
ok the error code is 43 witch is relating to the:
1. front o2 sensor
2. tps sensor
3. knock sensor
4. esc (electronic spark control)
another question would be is it possible that a stuck valve or something could set off the knock sensor?
Old 10-03-2005, 07:42 PM
Sounds like the knock sensor is gone to me. Check the wire running to it first of course. But it sounds likes its gone south....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-04-2005, 02:40 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
DAM 4 bolt main, aluminum heads!!! ID BE IN HEAVEN!!!!!!!!!!!!!!!! you lucky bastard, thats a big screw up on there part, BTW, why put that engine in with a stock exhaust system, sorta defeats the purpose dont ya think?
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 10-04-2005, 03:42 PM
Re: Re: 90 caprice 350 5.7 need help fast
I checked the sensor but it is working and there are no shorts or anything in the wire that i can tell.
two reasons why the exaust is still stock.
1. i dont have the funds for it.
2. i dont know a whole lot about exaust systems do you have any suggestions?
Old 10-04-2005, 09:16 PM
Have you used a scan tool of some kind to read the # of knock counts that you are getting?
Are you using the knock sensor for an LT1?
I seem to recall that those are really sensitive and many LT1 9C1 owners would swap to an LT4 sensor as they are less sensitive. Also I would bet that there is some kind of a compatability issue between the LT1 sensor and what the L05 computer is expecting....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-05-2005, 05:20 PM
i am using a sensor straight from the dealer (its not from the lt1, its just specified for a 350 engine) and i dont have a tool to count the knocks
Old 11-07-2005, 02:57 PM
just thought i would let everyone know that it was the Distributor that was messing everything up... the mechanical advance was sticking.
