Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-02-2005, 12:15 AM
quicksand quicksand is offline
96 oil leak
I have a 96 cutlass supreme 3100 intake gaskets were done about 3 months ago with the new felpro gaskets , now im getting an oil leak on the driverside i think around the lower intake but i can't really see where its coming from. i torqued the bolts at 10 ft pounds as the gm manuel says. but i was reading around and i believe someone gave some different torque information.
I was wondering if anyone could help me out thankyou
Old 10-02-2005, 06:37 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: 96 oil leak
You probably did absolutely nothing wrong if the car runs better than before you did the gaskets. Unfortunately you weren't informed about the distributor hole/oil shaft seal. The block still has a hole for a distributor. It is filled with a plug that holds a rod for the oil pump, this rod is turned by the camshaft. The plug was originally fitted with a rubber seal which over time it becomes brittle, breaks, leaks down the side of the bellhousing and makes it look like a severe oil leak. The solution is a replacement seal made of Viton(light brown colored). It's available through the dealer for like $2.00 The bad news: it's below the throttle body and the only way to get to it is to remove the lower manifold again. Sorry bout that. Good Luck -Chris
Old 10-02-2005, 10:25 AM
ok i hope its not that because its not a severe oil leak. since july not even a half a pint has leaked out. is that the only thing it could be?
