Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-01-2005, 09:59 PM
cold1 cold1 is offline
97 SL 1 Ignition smoke
When I turned the key to my 97 SL1 it hesitated to start, then smoke came out of the ignition and dash, now it wont start, what's the cause and how can I fix it?
Old 10-18-2005, 09:41 AM
bigron bigron is offline
Find the burnt components. It could be in the ignition switch itself also check for a shorted wire above the pedels there is a wire that will short on some models ussually around the clutch the insulation will be chared. Check your fuses
repair or replace as needed
