Old 10-01-2005, 09:57 PM
rickybortega rickybortega is offline
Question 99' grand caravan airbag light is on and horn don't work and cruise won't work
Well the airbag light came on first then the horn stopped working then the cruise stop working. Today I took the horns out and checked them to see if they work with 12volts going to them and they worked. I took the steering wheel apart and tried to bypass the horn and it did not work that way. And yes I checked all the fuses and I don't know how to check the horn relay to see if that is the problem. So please if you have any info let me know. Ricky b. Mesquite, Texas
Old 10-02-2005, 07:09 AM
KEVINP KEVINP is offline
have the dealership check to see if the clock spring recall needs to be done. this unit sits under the steering wheel.it efects the air bags ,horn, cruise control. if it hasn't been done it's afreebie repair.
Old 10-02-2005, 09:58 AM
vipergg vipergg is offline
Re: 99' grand caravan airbag light is on and horn don't work and cruise won't work
have the dealer replace the clockspring .
Old 10-09-2005, 07:55 PM
DP1976 DP1976 is offline
you might want to try to go on to www.dodge.com and go under "recalls", when you go there, type in your vin#, there has been a recall on this year caravan with that same problem. i have the same year caravan that i recently bought and have to get my van fixed before it gets to the problem you have!! I hope i helped!
