Old 10-01-2005, 09:55 PM
kimonagro kimonagro is offline
how to ground ALDL connector
i need someone to please tell me how to ground the ALDL connector i have been told i need to do this before i adjust the minimum idle speed
thanks in advance
Old 10-02-2005, 06:47 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Unless you have a carb and not TBI the ecm will handle the idle speed. Even on your 87. The aldl is for diagnostics on your truck, not programming. I think you're confused as to what your friend told you. You disconnect the ECM from the distributor for timing. Not ground the aldl.
Old 10-02-2005, 11:56 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: how to ground ALDL connector
On some model TBs there was an adjustment for min idle speed.
There is a special tool to block off the air port to the IAC and then you can turn the min. idle screw.
This is a base adjustment, the PCM controls the idle speed thru the IAC valve position.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
