Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-01-2005, 08:45 PM
DTangent DTangent is offline
Hub removal
Does anyone know where I can rent the tool to pull out the front hub from the knuckle? I have one with 3 forks on it for my ford, but it wont work on my Honda.
Tien SS coilovers
Ingalls Alignment Kit
Fluidyne HalfSize Rad
AEM CAI
AEM Fuel Rail
AEM FPR
**In the works**
New Garrett T3/T04E .63 A/R
Tial 38mm Wg
Tial 50mm BOV
Fixing the shit job the body shop did to my wrecked car.
Old 10-02-2005, 11:06 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Hub removal
You can rent them from most major parts stores (auto zone, o'rieleys).
Old 10-02-2005, 10:48 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
Re: Hub removal
I would go ahead and buy one. They come in handy. And they actually cost about the same to rent and buy one. I had to do an axle in a 93 civic and i didnt have one and i was just going to rent one and i think it was like 20 bucks from shucks and like 18 to buy it. And its called a pickle fork.
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
Old 10-03-2005, 09:16 AM
Forunn Daberator
Re: Hub removal
Pickle joint seperates ball joints, not removes hubs. And if you rent from autozone or o'rielies you get your deposit back in full when you return it.
Old 10-03-2005, 09:35 AM
Scrapper Scrapper is offline
AF Premium User
honda
all you need pickle fork is to loosen tierod..then you take 2 bolts out of strut and bolt out of lower balljoint this loosens everything you need and take brass hammer and smack the end of axle after you take nut off axle it should come rite loose from hub..pull hub off then there you have it...
good luck.....
RICK.......
Old 10-03-2005, 04:46 PM
Re: Re: Hub removal
Tried those guys already All they had was the same tool I have for my ford.
Tien SS coilovers
AEM CAI
AEM Fuel Rail
AEM FPR
**In the works**
Tial 38mm Wg
Tial 50mm BOV
Old 10-03-2005, 05:49 PM
Forunn Daberator
Re: Hub removal
Get a gear puller, line the middle up with the axel and pull it off.
Old 10-03-2005, 06:11 PM
AF Premium User
Re: Re: Hub removal
i'll tell you you really don't need pickle fork..but when you take the 2 bolt's out of strut that connects to hub..ok then take your bottom balljoint bolt out and you take little hammer if you do need to break it loose then you need a bar to pry down on lower control arm this will let your hub loose from everything you need to get hub off..and if you haven't got tierod loose yet smack rite beside where knuckle go's threw hole that is connected to hub.. now you do all that and knock axle loose.. it don't take much on axle to when you hit it you should have hole hub rite in your hand...i hope i exsplained it good enough anyway hope so?? let me know if you have any problems i do this day in and day out...
good luck to ya......
RICK..........
Old 10-03-2005, 06:18 PM
AF Premium User
Re: Re: Hub removal
RICK..........
Old 10-04-2005, 11:31 AM
Forunn Daberator
Re: Hub removal
Rick, you obviously dont do this day in and day out.
Old 10-04-2005, 02:39 PM
AF Premium User
Re: Re: Hub removal
i do do this every day..and you should have had it off in about 20 mins. i think you better take it to shop...
Old 10-04-2005, 04:37 PM
Forunn Daberator
Re: Hub removal
I think you need to learn how to read, I'm not the one trying to take it off Mr. Professional Hub Remover (man how did you end up with that shitty job... they run out of monkeys?)
Old 10-04-2005, 05:01 PM
AF Premium User
Re: Re: Re: Hub removal
yah we got some you monkeys out there i thought i knew you from somewhere..so your not the 1 with civic huh or do you even know??? and you need to get a real job like eating your dam banana's....
Old 10-04-2005, 05:10 PM
I don't see where I said "I tried to take it off and couldn't." I haven't even tried yet. I like to have the tools around to do something before I start. Go figure.
Maybe you should pay a little attention??
Tien SS coilovers
AEM CAI
AEM Fuel Rail
AEM FPR
**In the works**
Tial 38mm Wg
Tial 50mm BOV
Old 10-04-2005, 05:13 PM
Forunn Daberator
Re: Hub removal
Wow, people quoting themselfs and repling with illegable garble. Splendid.
Closed Thread
