Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 05-16-2002, 04:56 AM
BETTER THAN A WRX BETTER THAN A WRX is offline
INTERESTING: Wrong Oil = Poor Economy ?
Hi, I am still investigating why my T4 is getting bad economy.
The O2 sensor operates 9 times in 10 sec's @ 2000rpm, so
seems fine.
Got new plugs, clean filter, speedo is fine, no dragging brakes etc....
But; last time it was serviced (not at nissan) it got 20W50 put into it.
Now from reading abit about hydraulic lifters (which SR20's have), I have discovered that pumped up lifters can cause valves to stay open
for slightly longer duration.
Now too viscous an oil can cause the lifters to pump up when cold,
so I am wondering of this would have a significant effect on the compression ratio, and hence economy/power.
Has anyone come across this before?
Does it sound reasonable?
Later
Old 05-16-2002, 10:07 AM
howard_w13's Avatar
howard_w13 howard_w13 is offline
Question
20w50?!? Is that what the owner's manual recommends in New Zealand?
Far as I know the SR20DE should use either 5w30 or 10w30. Not sure about oil with that viscosity could effect fuel efficiency.
USA-love it or leave it!!!!!
:coolguy: :coolguy:
"Tis been my observation that a man that freely gives eveyone a piece of his mind ususally has very little left to think with."
Old 05-16-2002, 08:02 PM
No, the manuals are all pretty much the same.
Manuals/catalogues here recommend 10W30, but have been
told by a much that 5W30 is also good.
I just went to a generic jap import(car) mechanic to get a
filter and oil change, I asked what oil he was going to
use and he said that 20W50 was fine.
I think the problem is that many mechs just buy huge barrels
of generic oil to do most cars, so of course he is going to say it
is right.
The car is due for a fluid change, so I am going to REPCO in
the weekend, to get some engine flush and some nice 10W30.
Will see what difference it makes.
Later
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
