Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-01-2005, 07:46 PM
drummerguy drummerguy is offline
Engine "sputters" during hard acceleration!
Now I know that the obvious answer would be, well don't mash it......When I do get on it even just a little bit, the engine sputters, almost like a backfire but not loud and I can tell it's robbing me of power! Oh yeah, my car is '96, 4.6L, about the only modification is a 73mm throttle body and a FIPK kit. Any ideas? Thanks for reading!
-TJ
Old 10-03-2005, 07:38 PM
Scottoldboy Scottoldboy is offline
Re: Engine
-TJ
I spent weeks chasing the loss of power under acceleration in my 83 Bronco II. I felt like it was going lean. After three carbs and a carb overhaul, I realized it was always the same regardless of what I did. DAH, it must be in the ignition. I changed the coil and it ran great. Your problem could be similar. Under acceleration, cylinder pressure goes up and it takes more voltage to spark the plugs. A week coil, bad wires, or bad plugs could be to blame. Plug wires go bad more often than coils. - Scott
Old 07-29-2006, 11:09 PM
N2TRUKN N2TRUKN is offline
Re: Engine "sputters" during hard acceleration!
It Might B A Fuel Prob, Check You Fuel Pump Pre Filter And The In Line Filter. Also Check Fuel Presur. I Had A Pre Filter Get Cloged Did The Same Thing.
Oh Yea, If You Can Get On It Hard Whats The Use In Havin A Mustang. Right!!!!!!!!!!!
Good Luck.
N2trukn
Old 10-12-2007, 12:18 AM
gforcestangs gforcestangs is offline
after you check the fuel filter I might look into getting it tuned for your upgraded mass air meter..
