Old 10-01-2005, 07:13 PM
Escort419 Escort419 is offline
93' steering locked, key wont turn
I can not get my steering unlocked! and there for my key will not turn i tried everything........any help would be greeeeeeeatly appreciated
Old 10-01-2005, 08:38 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: 93' steering locked, key wont turn
some cars you have to pull on the wheel in either direction while you turn the key to unlock it. Also be sure (if auto) that the gearshift is in the park or neutral.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 10-02-2005, 09:36 AM
daleb9 daleb9 is offline
I hope you do get the key out, persevereance and good old WD40 usually does the trick. Once you get it out, put some powdered graphite into the keyslot, sprap with WD40, and repeat, that worked for me.
Old 10-02-2005, 10:59 AM
got the key out
Ok I got the key out, thats not the problem, the problem is....I tried everything from jigglin the key to turnin the wheel everywhich way, ,its still in lock position, The key will not turn at all!!! i tried wd-40 last nite, it wont turn still,any ideas before i have a locksmith come over, look at it? I dont know much about cars......
Old 10-02-2005, 04:35 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
While you're trying to turn the key move the steering wheel back and forth...
Nevada Tumbleweed
Old 10-02-2005, 11:27 PM
chevyn0va1's Avatar
thats what i meant
Old 10-03-2005, 10:37 AM
keyhole was jammed up , my key is so worn that it wasnt working right.....thats what locksmiths are good for thanks for all your help
Old 10-03-2005, 01:40 PM
chevyn0va1's Avatar
I used to have a van that happend too but it was the key that had a burr of sorts on it once it was simply buffed out it again worked fine.
