Old 10-01-2005, 03:55 PM
kimonagro kimonagro is offline
in need of some help before i go mad
i have an 87 s-10 when i leave it idling or stop at a set of lights it stalls on me to date i have changed the plugs ,leads,rotor,cap,timing,throtle body gasket ,IAC,TPS, looked for vacuum leaks and so far no success it id driving me around the twist can anyone please give me so other ideas.
thanks in advance
Old 10-01-2005, 04:53 PM
mayville1 mayville1 is offline
Send a message via AIM to mayville1
Idling
Can you adjust the idling on it??
2003 Ford Escape 4x4
2000 Ford F-250 4x4
1997 Ford F-250 4x4
1995 Chevy S-10 4x4
Old 10-01-2005, 06:10 PM
Re: Idling
i dont think u can there is no screw for adjustment
Old 10-01-2005, 06:50 PM
OverBoardProject OverBoardProject is offline
Banned
Re: in need of some help before i go mad
Probably too easy, but hows the fuel filter. And the fuel pressure
Old 10-01-2005, 06:56 PM
forgot to mention i changed the fuel pump and filter to how do you check the fuel pump pressure shouldnt it be correct cause it is an electric pump?????
Old 10-01-2005, 07:01 PM
Banned
Well a new pump should have the right pressure, but they use the same pump for V8 powered chevy's too.
This is why they have to regulate the fuel through a fuel regulator, which could also be worn out.
Old 10-01-2005, 07:07 PM
Re: Re: in need of some help before i go mad
ok dumb question where is the regulator?
Old 10-01-2005, 08:52 PM
Bads Crew's Avatar
Bads Crew Bads Crew is offline
Re: Re: Idling
My 87 had a idle adjustment screw. Look right in from the front where the cable is. Mine had a hole in the throtle body with an adjustment screw. I had a problem once inside my distribitor. Under the rotor there is a star plate with a magnet pick up. My truck wouldn't start. I changed everything. I saw that thet star plate had some light rust on it. I took it out and hit it on my wire wheel to clean it up and put it back in. The truck started rite up. I'm not saying that is your problem but its worth a try.
Old 10-03-2005, 09:19 PM
pulled the TBI off today and cleaned it up put new gaskets on it did the fuel pressure regulator and still no go.WTF is happpening.
Old 10-03-2005, 11:26 PM
TRACYCULBERSON's Avatar
TRACYCULBERSON TRACYCULBERSON is offline
Have you checked the throttle poisition sensor or maybe the map or o2 sensor
FAST
Old 10-04-2005, 12:37 AM
Re: Re: Re: in need of some help before i go mad
i put a new tps in i guess all i got left is an oxygen sensor and the map to anyone know how to test either????
Old 10-04-2005, 02:06 AM
no i sure dont no that one .But when you do solve the problem let me know i very interested in the cause of it
FAST
