Old 05-16-2002, 02:03 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
boosting the ZC...
Well i have only had my ZC in and running for about a week now... and i al ready want to add a turbo. Im thinking about doing the same setup as Cwbetb has (92-95 greddy kit) but need some more info as to if it is a direct bolt on or what.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 05-16-2002, 10:06 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
pretty much...you just have to grind a bit off of the corners of the manifold....knock a nice dent in the front cross member....creatively run the charge piping (or go custom)...get a FMU since the black/blue box wont work w/ OBD0... think that's about it.
how long are you going to break your engine in?
SOLD!
Old 05-16-2002, 03:08 PM
CWBETB's Avatar
CWBETB CWBETB is offline
Send a message via AIM to CWBETB
You need check valves also hooked up to the vacuum line
90 Turbo/ZC Civic
http://www.myspace.com/cwbetb
Old 05-22-2002, 08:36 PM
Poweredbyhonda's Avatar
Poweredbyhonda Poweredbyhonda is offline
Send a message via AIM to Poweredbyhonda
What are check valves?
How do they work?
Do you buy them or can u make them your self?
thanx
Kyle Cox
project eg hatch in progress
http://www.nsmotosports.cjb.com
:badass:
Old 05-23-2002, 11:00 AM
marked001's Avatar
Moderadur
check valves are simply one way valves that bleed boost off before it hits the MAP sensor (which will throw a code if it reads positive pressure)..you can get em for practically nothing at a pet store (for fish tanks) or the auto store...
SOLD!
Old 05-24-2002, 06:40 PM
optimuspeterson optimuspeterson is offline
Send a message via AIM to optimuspeterson
so is that the only thing you guys have to do to fool the ECU???
http://home.bendcable.com/optimuspeterson/ <<<<HRC Stage 2 and Star Instructions
95 GS
Mods: Probably a whole lot more than you.
Old 05-30-2002, 09:21 AM
marked001's Avatar
Moderadur
pretty much...other than that, just use slightly colder plugs, slightly retarded timing, and a boost dependent FMU...
SOLD!
Old 06-07-2002, 10:29 PM
reXem reXem is offline
if you have a little extra money you can get a proper 2bar(or is 3bar) Map sensor they are like 80 bucks I think....just if you wanna do professional....
