Old 10-01-2005, 02:03 PM
x8xViperx6x's Avatar
x8xViperx6x x8xViperx6x is offline
Send a message via AIM to x8xViperx6x Send a message via Yahoo to x8xViperx6x
Coolant Leak?
I parked my car in the garage and overnight I had a Puddle of Coolant on the ground, I looked but couldnt find where its coming from.. Im guessing the radiator is cracked.. Any suggestions?
1993 v6 3.4L
Old 10-01-2005, 02:07 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Coolant Leak?
Hoses???
Use some bubble gum.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 10-01-2005, 02:16 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Coolant Leak?
crack an egg into the radiator.....lol ,but i would try some bars stopleak before you go crazy.
Old 10-01-2005, 02:48 PM
Re: Coolant Leak?
I tried stop leak, I dont really like it cause that stuff just gunks up overtime.. an could clog the radiator it self, I had a problem with it in the past.. but, I may just replace the radiator and hoses.
1993 v6 3.4L
Old 10-01-2005, 02:51 PM
Mr. Luos's Avatar
Firebird Guy
Re: Coolant Leak?
I would just search deeper. Get the car in the air. Get at least an area the leak is coming from.
Motor?? Radiator?? In between??
Stock'ish'
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
look for little drops of water hanging... water will stick and slide down something till it can't go down anymore then it falls off... look underneath for drops then follow the water trail to your problem... if there isn't any try turning on the car and watching from underneath, see if you can see water coming down and pinpoint where its comin from
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 10-01-2005, 05:56 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: Coolant Leak?
The TB heater hoses maybe
Old 10-02-2005, 12:23 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Do you drive around with the A/C alot? The condensation will cause water to drop, not alot though but some. To see where the water is coming from.. turn on the car, open the hood and let the car heat up, when the fans kick on the water will start going from the radiator to the engine and such to cool off but if it is leaking you'll be able to see what hose is messed up or if the radiator is cracked somewhere.
Old 10-02-2005, 12:04 PM
Morley Morley is offline
Re: Coolant Leak?
The coolant system is a closed system and condensation has nothing to do with it...condensation is where the water in the Air condenses to form droplets...now IF condensation were affecting the cooling system...it would eventually become over full.
And the air conditioning has nothing to do with the radiator or its fluid level.
Check your oil for signs of water (looks brown like mud), check the underside of the oil fill cap. check the exhaust for white "smoke".
Old 10-02-2005, 11:56 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Coolant Leak?
STOP the stop leak.
it's probably something petty and running a motor pumped full of stop leak with no where to go only causes more problems like a cracked block
Old 10-03-2005, 11:12 AM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Coolant Leak?
this is an easy one... STEP 1 Locate leak... Step 2 come back and tell us where it is....Step 3 fix leak...
Just get under, over, and inside of that car looking for your source of leak... you'll find it...
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 10-03-2005, 11:16 AM
Re: Re: Coolant Leak?
um... i'm pretty sure rally was implying it might not be antifreeze and could have been water.....
Old 10-03-2005, 10:37 PM
Re: Coolant Leak?
ok, ill be right back, im going to check it out... ill tell you if I find the "source".
1993 v6 3.4L
