Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 10-01-2005, 12:52 PM
onequickstick onequickstick is offline
problem with brake lights
I dont seem to have any power gong to my brake lights. checked all the fuses, replaced the break light switch and still not working. All the tail light functions ie flashers, signals backup lights work fine. Any ideas,
Thanks
Old 11-07-2006, 06:02 PM
freefalling freefalling is offline
Re: problem with brake lights
we have the same problem with our 2004 dodge dakota. started after we hooked up the trailer. trailer unhooked and no brake lights on the truck. anyone know how to fix it?
Old 11-08-2006, 03:04 AM
KimMG KimMG is offline
AF - Advisor
Did you check to see if you are getting power to the sockets?
Old 11-08-2006, 10:44 AM
power to all sockets, except the brake socket.
Old 11-08-2006, 11:43 AM
AF - Advisor
Did you check the fuse(s) for power and continuity? Did you check to see if power is going to the brake light switch? How did you install the brake lights for the trailer? Could this possibly be a warranty issue?
Old 11-08-2006, 12:21 PM
yes, we checked the fuses, etc., and for power going to the brake switch. we even replaced the brake switch. the trailer was hooked up with the standard wiring. there is power running to all the trailer switches, except the brake (which makes sense since the truck's brake lights are not working). we are going to try rerunning all the brake wiring since there is no other obvious cause.
