Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-01-2005, 11:26 AM
killerpin killerpin is offline
Question head swaping
ok my pops gave me the shitty est integra but i jus love this car..... now my problem is rite, it is a DC1 integra with the zc engine.. now i'm supposed to be gettin a b16 head from a friend and i was wondering if puttin the b16 head on the zc would increase overall power(hp/torque)
if this would help, any body have any information on how well it would work, if it would work at all. and wat i would need to complete it
Old 10-01-2005, 11:37 AM
NY91TegOwner NY91TegOwner is offline
Send a message via AIM to NY91TegOwner
yea i have the same question don't mean to steal the thread or anything but i have a 91 integra and i was wondering if i swapped the head out for a vtec head would i have to adjust my timing or my computer or anything like that
Old 10-01-2005, 11:47 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: head swaping
B-series heads will not swap onto it.
Old 10-01-2005, 01:30 PM
Re: head swaping
i know that u would deffinitley have to change yur computer to the computer for the head aka b16 head computer. timing ...well i'm geussin yes because yur movin to dohc rather than sohc my problem is if the head can be bolted to the sohc block n how much modification would be needed to do it....i know it can be dun
Old 10-01-2005, 02:43 PM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
Re: head swaping
you cant bolt a b series head onto a d series block....
Old 10-01-2005, 02:47 PM
Re: Re: head swaping
explain to me y ? is the head bolt pattern different or sumthing?
Old 10-01-2005, 05:45 PM
CivicSpoon's Avatar
There is no Spoon
Re: head swaping
yes the bolt pattern is different, as well as size.
Old 10-01-2005, 07:45 PM
93dxls 93dxls is offline
Re: head swaping
look at the size of the motor totally different your best bet would be to ditch the zc and go for an ls which is dual cam then you can do the ls/vtec mainly the wiring is the biggest thing
Old 10-02-2005, 10:51 AM
yeah thanks people i know it can be dun but i found out that the power increase is not worth the trouble, time and money to get it dun soo i'll source a b20 block n move from there. any ideas as to where i can get a b20 block with pistons and crank shaft for reall cheap? take into consideration that i'm from the caribbean and i'll have to deal with shippin too. thankxx...oh and both the zc and the b16 are 1.6liter motors.... y the question about size?
Old 10-11-2005, 01:39 AM
~ls/vtec~'s Avatar
Re: head swaping
the bore on the b series blocks is 82mm (i think, it has been a few months since i dealth with little details like this) and the one on the d series is somewhere around 76mm... i might be wrong on the exact sizes but you get the point..i hope.. now think of the difference in stroke. and how are your cams going to work with the really different stroke of the pistons.
swapping heads is an interesting thing to do..but on the same series of motors. what you are asking is bassicaly - how can i bolt up an accord transmission to a s2000 motor. just cant be done...youre saying the motors are both 1.6 so there should be a difference....the s2k motor is a f20c. the accord is a f22.
Old 05-06-2006, 07:33 AM
Re: head swaping
yeah thanks for the info.......
trying to find sum info on the b20 vtec....how it is dun step by step instruction....and what harness and what needs to be dun to it to make it work.
