Old 10-01-2005, 10:20 AM
onej onej is offline
Sl Turbo?
Does anyone know where i can find a turbo kit for my SL
Old 10-01-2005, 10:31 AM
2Devious 2Devious is offline
Re: Sl Turbo?
You can find the kit on a VR4.
Check the faq it has a ton of info on adding turbo to an NA.
1998 Mitsubishi 3000GT SL - Pearl White
Ralliart Filter | Bomz Intake Body | 3SX Lightened Crank Pulley | 3SX Polished Spark Plug Cover | Blue silicone hoses | Polished plenum | Painted / detailed valve cover | De Corsa Fusion Black 18x8.5 wheels | White/Blue Glow gauge faces |Pioneer DEH-P770MP Head Unit | Lilliput 7" motorized touchscreen | Audiobahn 6x9s | Audiobahn 5.25s | Audiobahn ATB10AT Sub | Stinger Digital 1.2 Farad Cap | AMD XP 2100+ CPU | 1G Ram | 60G HD | SBLive! | Nvidia GeForce
Old 10-01-2005, 03:02 PM
compaqpunch compaqpunch is offline
Re: Sl Turbo?
their are not a turbo kit for an sl.
Old 10-01-2005, 07:31 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Sl Turbo?
true, there's not a turbo "kit", but you can just take the stock turbos and all turbo accessories from a VR4 and they will bolt right up to a base/SL
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-01-2005, 08:55 PM
Jimmy Neutron Jimmy Neutron is offline
Send a message via ICQ to Jimmy Neutron Send a message via AIM to Jimmy Neutron Send a message via Yahoo to Jimmy Neutron
Re: Sl Turbo?
look/search around on 3si.org/forums, there is a good handful of ppl that have done twin and single turbos, with pics
96 3000gt Vr4 green+tan, fresh engine, lots of little problems, surprised? not at all
Old 10-02-2005, 08:33 PM
Hotshot8792 Hotshot8792 is offline
yes, my friend has all the major parts for a tt conversion. Has everything but some nuts and bolts, electronics, boost controller, and gaskets.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
