Old 10-01-2005, 10:19 AM
joeruff joeruff is offline
1997 PA door panels
Need help removing door left door panel on '97. Can't find screws. Any suggestions?
Old 10-04-2005, 02:54 AM
bigsky bigsky is offline
This is for the left FRONT. Inside the door handle there is a plastic plate that pops out and there are a couple of screws. Pop out the red light near the back of the door...there is a screw there also. With the door open, look in the round duct hole. There is a plastic pin there that was a pain for me to remove. After breaking the head off with a pliers, I could finally get a hold of the pin with pliers to pull it out. Finally there is a plastic trim around the metal door handle that can be popped out...can't quite remember which side to pry from...I actually didn't do this. Door then just lifts up and out. Remember to disconnect the electrical connector behind the door when removing it. Overall, it was fairly easy (usually is AFTER you do it.
Old 01-10-2006, 07:13 PM
dksram
Guest
Posts: n/a
This will HELP
http://autorepair.about.com/library/faqs/bl243i.htm
GO TO THIS SITE> IT WILL GIVE YOU PHOTOS
