Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 10-01-2005, 08:58 AM
bugwugly bugwugly is offline
Send a message via AIM to bugwugly
Angry code 1128 for 2000 beetle
Hello there everyone! I have been reading this site for quite some time now and I have a problem that I don't know how to deal with. My check engine light is reading a code P1128 (which is fuel metering, too lean, bank 1) and I was wondering if anyone could tell me what part (or parts) i should be looking into. I have recently replaced my O2 sensor, MAF sensor, engine coolant temperature sensor, checked my air filter, and replaced my spark plugs. My beetle is a 2000 2.0L with 65000 miles. Any help would be appreciated! Thank you so much!
Old 10-06-2005, 12:44 AM
fozzy18's Avatar
fozzy18 fozzy18 is offline
Re: code 1128 for 2000 beetle
I had kinda of the same problem, did u touch the o2 sensor? because i did and it was the worst headache of my life!!! and found out it was the o2 sensor i had touched. after i changed the sensor everything was all good!! stopped geting the p1128 code, so if you did theres your problem
Old 10-06-2005, 02:07 PM
Re: Re: code 1128 for 2000 beetle
I am not sure if the sensor was touched, i had a shop do it. However, I noticed that I had a loose vacuum hose the other day so I replaced the hose and clamps. Could that have been the problem? And thank you for your help and advice.
Old 10-06-2005, 02:18 PM
fozzy18's Avatar
Re: Re: Re: code 1128 for 2000 beetle
If it is a large hole or its sucking a lot of air it could be your problem
Old 10-07-2005, 01:36 PM
Re: Re: Re: Re: code 1128 for 2000 beetle
the leak was audible with the hood closed
Old 10-07-2005, 01:45 PM
vamc's Avatar
vamc vamc is offline
P1128
17536
Long Term Fuel Trim B1 System Too Lean
http://www.troublecodes.net/VW/96-00mot.shtml
Old 10-07-2005, 01:51 PM
vamc's Avatar
I hope this helps a little
Old 10-08-2005, 01:33 PM
boschmann boschmann is offline
Vacuum leaks are a common cause of that code.
