Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-01-2005, 01:04 AM
sup296 sup296 is offline
Unhappy Engine noise
When I was going at like 70 on highway, I hit the brake real hard cuz the car in front of me did so. And right after that, my engine started to make weird noise. After 3000rpm, some kinda clicking noise can be heard from the engine. I had 2 different engine mechanics take a look at it, they both said it's from piston or the motor (dont really know what he meant by "motor"). But my friend in auto shop says it's cuz I dont put the premium gas so there is not enough explosion to make the piston move cuz my car has 52000 miles. The mechanic said 1400up to fix it, around 1800 for used motor. But I cant spend money on someting Im not really sure. Need your opinions!
And planning to get Magnaflow muffler #14814. Would this be a good choice for nice deep sound? I dont want high loud noise sound. I was wondering whats different b/w oval type and round, single wall and double wall, straight cut tip and angled cut. So if you could let me know about this too, that would be great.
Thanks for your help!
Old 10-01-2005, 03:19 PM
Thruster Thruster is offline
Send a message via AIM to Thruster Send a message via MSN to Thruster
Re: Engine noise
i thought premium gas was supposed to give less of an explosion?
Old 10-01-2005, 09:45 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Re: Engine noise
premium gas is meant to prevent detonation or pre-explosion,
as for your noise, if it is a ticking noise kinda that sounds like its coming from the motor, it is possibly a noisy lifter, there is a quick fix to that, or if you don't get your oil changed at the dealership w/ a mitsu oil filter, then that is supposed to be another cause of it...something about a dual stage filtering...crap i don't know
mine does the lifter noise thing and it has 18k miles...its been like that for prolly 10k miles and i did have to brake hard...so i don't kno
Don't act like you don't love it.
503/2000
Old 10-02-2005, 05:04 PM
Re: Re: Re: Engine noise
I get my oil changed at my friends auto shop. Do I need to change at Mitsu dealer? I guess Im gonna ask ppl around here.
Just curious after searching, but why is magnaflow recommanded? I thought Apexi N1 or some other HKS things are pretty good, too.
THanks.
Old 10-02-2005, 07:34 PM
Sleepr awd's Avatar
Re: Engine noise
magnaflow is generally pretty cheap compared to other companies and i just buy my oil filters from the dealership now, haven't gotten to change the oil to see if the mitsu oil filter works better yet...its still a theory
503/2000
Old 10-03-2005, 08:32 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: Engine noise
ive never used a factory oil filter...my car has 82k with no engine problems
Old 10-03-2005, 01:15 PM
Hmm. Thanks for you help. Imma find out later.
Old 10-11-2005, 02:35 AM
Djinon Djinon is offline
Send a message via AIM to Djinon
I'm having that same clicking noise. It can start when I turn on the car, idling, and is intermittent. A shopmate of mine told me it was one of the valve covers not being spaced properly. He said I need to take off the engine cover and use a feeler gauge to reset the distance. Haven't had the time to do it.
Old 02-02-2006, 01:49 AM
AzN-SoLjA CS AzN-SoLjA CS is offline
Re: Engine noise
oil change or add oil
i hear about this clicking thing hella times
its the oil being low
Old 02-02-2006, 09:38 AM
Sleepr awd's Avatar
Re: Engine noise
i've got the appropriate amount of oil castrol synthetic, its still pretty much golden/brown, and a mitsu oil filter
i don't think its the oil
of course i have TOB rattle and lifter tick now, so its just plain annoying anyway i look at it
503/2000
Old 02-02-2006, 04:54 PM
808drifter 808drifter is offline
Re: Engine noise
Ok I am an ASE certified mechanic.
The reason ther wanna charge you an arm and a leg is because they dont know whats wrong and have to pull the motor.
As for the lifter hiting the valve cover i doubt thats it. Ive taken off mine to panit it and theres alota room between the cover and lifter at full raise. (not sure on v6 though.)
the oil thing is plausable but only on oil level not how lod it is. Oil filter, Just do it your self and save some money (unless you get it free under warenty) it just anit that hard , as for the filter just get a FRAM the make dual stage filters its there base line model.
Old 02-03-2006, 04:00 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Engine noise
People say that FRAM filters suck ass, I use the high mileage FRAM filter with Mobil 1 Full Synth. I have never had a problem with my oil. And to whoever keeps saying low oil makes your car tick...please explain yourself because you have posted it twice in 2 posts and no one seems to agree with you.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 02-04-2006, 12:05 PM
Sleepr awd's Avatar
Re: Engine noise
they mostly suck ass on turbo cars, they tend to blow through, a buddy of mine had one on his car, and the guy at o'reilly said " ur not really getting a fram are you?"
that was the end of that, i'll use wix or the mistu ones
and as for it being the oil low
503/2000
Old 02-06-2006, 08:46 AM
Re: Engine noise
i've heard plenty of horror stories. the filter inside of FRAM's are cardboard and they are GLUED in. yes, glued. the glue has been known to come apart. nothing good can come from your oil filter failing.
Old 02-06-2006, 08:53 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: Engine noise
They are cardboard and glued in. If i can find the one i cut i will post it. I have cut alot of different brands apart to check them out . But frame is junk!!!!
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
