Old 09-30-2005, 10:30 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Question water temp guage.
well eveyrone im jsut tyrin to ask hwo oy uinstall the sender. do oy uinstall it in the stock mount under the dizzy. if so then thats all i really needed.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 09-30-2005, 10:48 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
WOW! Your spelling is HORRIBLE!
Old 09-30-2005, 11:31 PM
DTangent DTangent is offline
Sounds like you already know the answer.
Yes, the sender is located under the dizzy. A green wire leads to it. You will be replacing it right?
**Edit**
I just realized that "oy uinstall" = you install. I was reading it as uninstall. Anyway, yes, replace the stock sender which is located under the dizzy, if it will fit. Most aftermarket water temp gauges come with senders that are to big to fit our engines.
Old 10-01-2005, 12:47 AM
Re: water temp guage.
yea so i suck at typing but at least my point was quite clear to someone. as for replacing it yes i am my autometer guage came with a new sender.
06 cbr 600 f4i
91 civic hatchback.
Old 10-01-2005, 12:51 AM
Re: Re: water temp guage.
The sender that comes with autometer gauges is to big. You will have to locate the sender somewhere else. I put mine in the line coming from the tb. And no, you can't use the stock sender
Old 10-01-2005, 06:29 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
or retap it into the head.
i believe autometer actually has info covering this.
anyways, if your stock temp gauge still reads hot and cold, thats all you really need.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-02-2005, 08:28 PM
i think everyone is kidna yankin my crank sayin the stock snesory wont work. becuase iwas catching a signal off of it. wasnt driving around but i was catching one.
06 cbr 600 f4i
91 civic hatchback.
Old 10-03-2005, 05:09 PM
Are you saying your stock sendor will work with an autometer gauge? If so, try it. 100 bucks says it wont.
Tien SS coilovers
Ingalls Alignment Kit
Fluidyne HalfSize Rad
AEM CAI
AEM Fuel Rail
AEM FPR
**In the works**
New Garrett T3/T04E .63 A/R
Tial 38mm Wg
Tial 50mm BOV
Fixing the shit job the body shop did to my wrecked car.
Old 10-04-2005, 10:55 PM
when i get my guage pod to put the guages in ill chech fully. i coudlnt test it much cause it was all ghetto rigged just to see if it would work and i knew hwo to do it.
06 cbr 600 f4i
91 civic hatchback.
