Old 05-15-2002, 11:54 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
D16z6 vs D16y8
Hey, guys, whats the difference between d16z6 and d16y6??? I want to do a Sohc Vtec swap into my DX, first off, what are ALL the parts in doing an Dual point to Multi point swap? and also, how the freak do i do it? Any body got a GOOD write up on it? and also, i want to put in a SOHC Vtec, what parts do i need for that? do i keep anything from my car? and also, does anyone have a GOOD write up on how to wire in the Vtec? and what controller should i use? and what process do i gotta do in doing the actual SWAP!? I have seen'd Ami's stuff about it, but i need something more detailed because me and my mechanically inclined friend are gonna give a WHACK at it and i think maybe if we read about it first, it wont be as much of trial and error.......... So, any help would be great guys, thanks!!!
Old 05-16-2002, 12:20 AM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Wow that is an arse load of questions, so you want to know about changing from dpfi to mpfi, then how to do an engine swap, then how to do a d16z6 or y8 swap, then how to get vtec activated? Check out honda-perf.org, ami's write up, and find a good write up on engine swaps, as for z6/y8 I believe that z6 is pretty much plug and play, while y8 may need a little more work, but im not exactly sure on this Im investigating it myself. The reason being our cars are non OBD, but the newer engines are ODB-I and OBD-II. Also the y8 has a higher compression which equals a little more HP plus the engine would be newer as well.
Old 05-16-2002, 11:25 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
that was a lot of questions!
for the MPFI conversion>>>there is a how-to in this month's Sport Compacy (june 2002).
the 2 engines are basically the same. not really a big difference. i know there is a difference in how the distributor mounts depending on which engine and what year car it is from. and i believe the wiring harness (or the way you wire it if you try that way :licker: ) is made a little different. possibly to compensate for the different distributor...not postive on that one. it's early *need coffee*
here are swap info links:
http://www.geocities.com/bing_bong916/vtec.html
http://hybrid2.honda-perf.org/tech/sohcvtec.html
http://www.geocities.com/kurtsi_on/page7.html
http://www.geocities.com/crx288/d16z6swap.html
http://www.geocities.com/motorcity/...115/4gtech.html
http://www.angelfire.com/ca/DrOhm/hybrid.html
http://integra.vtec.net/engine/vcontrol.html
that's it! there has been a lot of talk on this swap at the board. as soon as i get some time i'll just make a page for freq> asked Q&A and links...then maybe make it sticky or something.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-16-2002, 02:21 PM
CRX586's Avatar
CRX586 CRX586 is offline
D16Z6
What can I expect to pay for this swap (assuming I already have MPFI)...?
Old 05-16-2002, 06:10 PM
it all depends on what sort of deals you find, but expect at least 1000 by the end.
Old 05-16-2002, 07:03 PM
amy@af's Avatar
i found the info you're looking for :jump:
D16Z6
92-95 Civic Si
92-95 Civic Ex
93-95 Del Sol Si
tech specs:
-1590cc
-4 cyl, 16 valve
-SOHC VTEC
-9.2:1 c.r.
-PGM-FI (MPFI)
power/redline:
-125 bhp @ 6600
-Redline: 7200 rpm
torque:
-106 lb-ft @ 5200
D16Y8
96+ Civic EX
tech specs:
-1590cc
-4 cyl, 16 valve
-SOHC VTEC-II
-9.6:1 c.r.
-PGM-FI (MPFI)
power/redline:
-127 bhp @ 6600
-Redline: 7200 rpm
torque:
-107 lb-ft @ 5500
Old 04-14-2003, 06:18 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Which one would be better to aim for? The z6 or y8?
Old 04-14-2003, 07:54 PM
amy@af's Avatar
well it depends. in all honesty, i recommend the z6. the swap has been done many times. no real shady areas. you know how honda likes to tweak the impeadence (sp?) of the fuel injectors? well it changed again in the y8. jer never did figure out how to wire up the mpfi if going from d15 to d16y8. i'm sure if he sat there and thought it out....he'd get it. i had a Si so no need to bother. i say screw all that drama. get a z6 and follow the instructions found all over the net. drop it in and done
check the engine section at the civic site for the links we used during my swap...they should be a big help
Old 04-14-2003, 08:16 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
What one has more power? or are they the same
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 04-14-2003, 08:58 PM
GTA's Avatar
GTA GTA is offline
Whee..
the y8 has 2 more hp and 1 more ft-lb of torque.. so they are pretty much the same.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-14-2003, 09:08 PM
Cjz89civic's Avatar
AF Premium User
Ok so my new fresh rebuild d16z6 will be ok then.
Old 04-14-2003, 09:12 PM
GTA's Avatar
GTA GTA is offline
Whee..
nah, it'll suck you should sell it to me for cheap
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 04-14-2003, 09:25 PM
amy@af's Avatar
be okay for what? lol
all i have to say is......if it's a fresh rebuild....let it BREAK IN for at least 500 miles. go for a short road trip or soemthing before you try and see what it's got.
you coming up in may?
Old 04-14-2003, 09:52 PM
Cjz89civic's Avatar
AF Premium User
"Okay" as far as power goes. I just rebuilt it went .020" over and had it port and polished more polished that ported cause the ports where allready pretty close. All new bearings, rods, drop forged pistons, head gasket, all gaskets, and knife edged the crank. So will see. Dont know if Ill get it in before the meet at your place but I so hope so. I want to break it in before the trip. Oh ya Im still planing on going up there.
88CiViC_DX
Umm ok cheap = what I got into it so far lets see $800 is all it has cost me.
Old 04-14-2003, 10:47 PM
MyFirst4G's Avatar
WOW, this thread is so old, back when i was actually MyFirst4G!!!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
