Higher compression....spark?
Do you want a cooler plug with a higher compression motor??
Stock is 10.1:1 compression, and the NGK TR55's work perfect. New motor is 11:1 compression. Thinking I will try the NGK TR55's once and the NGK TR6's once. The TR6 is a cooler plug. Opinions??
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
Re: Higher compression....spark?
I'm thinking you want to run a cooler plug. Higher compression engines require higher octane fuels to resist detonation, right? So I would assume you want a plug a bit cooler, to prevent pre-ignition?
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson |
Also you will ping all the way on 94. I would go with cooler ones
I will be able to run 91 at this altitude with no ping. Plus, the quench is tight enough to help avoid detonation.
Premium alone will be good enough. Too much more and I am asking for problems.
