Old 09-30-2005, 07:41 PM
scratchmaster_x scratchmaster_x is offline
Send a message via Yahoo to scratchmaster_x
Question 91 grand am engine noise!!!!
i recently bought a 91 grand am and it had a timing chain cover leak....
i was getting around to fixing it when one day i was coming home from work and the oil light came on and the engine shut down so i pulled over and found 4 quarts of oil in my trunk.. put them in and got about 2 miles and it was out already .... i still had about 2 miles to go to get home so i PUSHED IT .... babied it home but the engine started making a loud "RAPPING" noise ..... so n e wayz i fixed the timing chain cover leak and took off the oil pan and low and behold the rod bearings where like paper thin..... so i replaced them hoping thats what was giving me that rapping noise ..........BUT it wasnt , i checked all the rods -straight-
checked the rockers -tight- ,took the head off- valves seated correctly,
i cant figure out what the heck this noise is SOMEONE HELP!!!!
im thinkin tis the output bearing beacause it dont do it when u have load on the car (going uphill and things like that) u hear it when its in park and u rev it a lil bit and the load is about to come down but u push the pedal a lil bit harder and it goes away ,as long as u keep load on it u dont hear it ...........
AM I RIGHT ABOUT THE OUTPUT BEARING????????
need input immediately
Old 10-01-2005, 08:55 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 91 grand am engine noise!!!!
it sounds like the main bearings are gone . THey make a deep thumping sound that you can here when the throtles held at a constant rpm(3k or so). which sucks since you just had the oil pan off. Get some plastic gauge and mic the main bearings, I'd bet thats the culprit.
1999 Grand Am SS 3.4 OHV
