Old 09-30-2005, 07:00 PM
angelicdemon's Avatar
angelicdemon angelicdemon is offline
Question HELP! Motor Mounts 99 Grand Am
I have a 1999 Grand Am that shakes when I come to a stop almost to the point where I think that it is going to die on me. I took the car to a mechanic and he said that I needed new motor mounts because the ones that were on the car now were collapsing. How expensive is this? I was quoted a price of 400 and while I know that it's not a lot of money to spend on a car, right now I don't have any extra money. Is there something else that it could be???? Any tips, advice, suggestions, or whatever would be greatly appreciated.
Thanks!
Old 09-30-2005, 10:22 PM
Re: HELP! Motor Mounts 99 Grand Am
okay, just found out that it is the rubber bushings that are almost gone, but the mounts are fine. is that something that can be replaced or do i have to get the mounts replaced too?
Old 09-30-2005, 11:39 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Re: HELP! Motor Mounts 99 Grand Am
The rubber component is the only part that should need to be replaced. It is the part that fails, not the actual metal part that it attaches too. 400 is an appropiate price for the parts and labor combined. But I would inspect the mounts yourself and make sure it is actually the detiorated rubber that is causing the vibration. You said you think "it is going to die on you". Is there some symptoms you can tell us? If your engine is just simply sputtering / misfiring, then it's deffinately not mount related - it could totally be something different. Inspect the mounts, and then you'll know for sure if they actually are the culprit.
Old 10-01-2005, 12:57 AM
i just think that it is going to die on me because of the way it shakes. it doesnt' sputter or stall or anything, but it shakes so bad sometimes that i just dont' trust that it's going to stay running. scared that i will be there and my motor is going to lay on the road.
Old 10-01-2005, 06:29 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The rubber is part of the mounts.
If the mounts have collapsed, this will cause a firing frequency vibration through out the car and would make you believe that your car is running rough.
Replace the mounts and everything should be fine
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
