Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-30-2005, 05:40 PM
rdharley3 rdharley3 is offline
1999 Tahoe check engine light HELP!!!!!
My 99 Tahoe's computer is giving a trouble code of 420 Catalytic trouble bank 1. I was told to check the catalytic converter off the drivers side manafold, check the O2 sensors, tune-up, replace pcv valve, and run on premium fuel W/recommended additive (Sea foam).
I took the tahoe to a muffler shop they checked both converters (heat tested) and told me they were fine, they also stated that 420 was not the trouble code indicating bad O2 sensors so they feel like they were not the problem. I changed the plugs, plug wires, distributor cap, rotor button, air filter, pcv valve, and run high octane fuel w/ additive (sea foam) and still I have the same problem.
The Tahoe runs great the only problem is that we have to VET test our vehicles and reguardless of what your emmissions are with that code they will not pass it, and you cannot get a waiver after spending xxx amount of dollars trying to fix it, You fix it of no tags.
I don't know what else to do any suggestions would be greatly appreciated.
RDH
Old 09-30-2005, 07:38 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 1999 Tahoe check engine light HELP!!!!!
RDH
First...DO NOT use high octane gas in your vehicle..it was designed to run on 87 octane and using higher octane could cause undesireable driveability concerns.
Read here for more info
Secondly, the code P0420 is for catalyst efficency, meaning that the catalyst cannot convert the HC and other pollutants. The only repair is to replace the converter (which is covered under a 8/80 warranty)
A heat test is NOT a valid test to determine whether or not a converter is working properly.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-30-2005, 10:23 PM
maintainin76 maintainin76 is offline
Merlin is right. It is a bad cat. Mine had the same code. If you have under 80k on the truck, take it to the dealer. They'll replace them at no cost to you.
Old 10-02-2005, 12:07 PM
Thanks for the info. I had the cat replaced and all is fine.
RDH
