Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-30-2005, 03:28 PM
swampfox712 swampfox712 is offline
Send a message via Yahoo to swampfox712
can't figure out overheating
Hey all,
I have a 2000 4.7 V8 Dakota, has about 87k miles now.
First started overheating about a month or so ago. No big deal -- it was a hot day, I was driving up over a 8,000ft mountain pass. Replaced the water pump and thermostat.
Ran good for about a week, then started overheating again. Turns out the AC pulley was bad. Replaced that.
Ran good for about three days, and now it's overheating AGAIN. Any thoughts on stuff I HAVEN'T replaced yet?
And please don't tell me I need a new radiator ... I've put over $1,000 of parts into this truck that I JUST BOUGHT in May ....
Old 10-11-2005, 08:37 PM
troy1 troy1 is offline
AF -Advisor
Re: can't figure out overheating
radiator is a possibility how about having some air trapped in the coolant system. not to familiar with the 4.7 does any one know if the 4.7 has bleeders for the cooling system?
Old 10-11-2005, 09:05 PM
Dakota00's Avatar
Dakota00 Dakota00 is offline
Send a message via MSN to Dakota00
Here's a pic, where the bleeder is.
You can see the screw hole between the alt and steering reservior.
Old 10-11-2005, 09:26 PM
knox 000's Avatar
knox 000 knox 000 is offline
have you had the rad cap pressure tested. it may be as simple as buying a new cap. what temp thermostat did u use might be too hot. if not im sorry too say its most likley the rad.
Old 10-12-2005, 10:11 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
also, make sure you fan clutch hasn't gone bad as well. A faulty fan clutch will cause the motor to overheat in addition to what everyone else has stated.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 06-28-2007, 08:30 PM
robert341 robert341 is offline
knowing that you have already changed the water pump you may want to check the flow especially if was a reman pump
