Changing bulbs/lamps on Instument Cluster
Hi Folks
I need to change one or two lamps/bulbs on my instrument cluster. To do so I may need to disconnect cluster from wiring in order to remove cluster backing cover. After replacement of faulty lamps & replacing the cover & connecting back up, will I need to have the computer re-set? If so, this seems heavy penalty for just changng lamps so hopefully re-setting is not required unless one actually changes the cluster for some reason. Any advice most welcome. Regards Dave |
Be sure to do a search on removing the instrument cluster and the SRS light. There are a couple tricks, and you don't want to trip your SRS light! What year is your car?
Re: Changing bulbs/lamps on Instument Cluster
Rgds. Dave |
Re: Re: Changing bulbs/lamps on Instument Cluster
Good luck. |
Re: Re: Re: Changing bulbs/lamps on Instument Cluster
David |
