Old 09-30-2005, 12:08 PM
sitnlow sitnlow is offline
Interior painting
Anyone have a technique for really good interior painting? Every time I do it, it comes out pretty bad. I tried on my girlfriends' Accent and it worked when I just simply washed and dried the pieces, no primer or nothin. But when I try to do my hatch interior pieces, the paint runs, etc. '
thx
Old 09-30-2005, 01:56 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Interior painting
Sand it down with some ricepaper and use good quality paint (ie dont rattle can it).
Old 09-30-2005, 02:19 PM
e-flightvic e-flightvic is offline
on my civic, I also did the mistake of using cheap wall-mart paint. but if you have no other solution. then this is what I did.
Clean the area with a degreser. Then lightly sand the surface of what you're ganna paint, by hand. Then prime it with a good healthy coat. paint one coat from top to bottom, then return from bottom up. Do this 3 times(3 coats) with 1 hour drying time between coats. clear coated 2 times with also 1 hour drying time(guessing that you're in a dry warm area)
This are just my .2cents everybody has difrent ways of painting..
Thanx
