Old 09-30-2005, 11:06 AM
simplyslammed simplyslammed is offline
Unhappy best memory/turn-on wire?
hey everyone. just installed an amplifier with subs in my cav. I have no aftermarket radio. so I had to use an impedence adapter... anyways... but the amps always on so I gotta find a good turn-on wire that is easy to access. any suggestions??
Old 10-05-2005, 01:47 PM
knipS knipS is offline
get an aftermarke head unit or just hook the amp to a taggle
Old 10-05-2005, 02:46 PM
cdru's Avatar
cdru cdru is offline
Re: best memory/turn-on wire?
If you don't mind having the amp turned on whenever the car is on (regardless of the radio being on), just find a switched accessory power wire and use it for your sense. You shouldn't have to worry about current issues as it will be very little.
Vinyl adds horsepower, right?
Old 10-05-2005, 03:40 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
im in your same situation, what i did was ran the remote wire into the fusebox, hooked it up to the windshield wiper fuse, and also put a toggle switch underneath the drivers seat, just in case i wanted to turn the amp off without turning off the car, before i had just the toggle switch but after many times of forgeting to turn it off, i learned my lesson the hard way when i went to buy a new battery
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-18-2005, 01:32 PM
Kool thanks a lot guys. Its really working out for me. Appreciate all your help.
