Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 09-30-2005, 10:54 AM
crossman83 crossman83 is offline
Engine Bogs
I have a 1968 Chevelle with a 350 and a Holley Street Avenger 650cfm carb. When i mash the pedal at a stand still in drive, the engine will bog for a second and then kick in. If I'm cruising along and then mash the pedal it won't bog. Do I need to set my fast idle at a slightly higher RPM so when it's in drive it idles a little faster, or is my mix too rich or too lean? Any ideas would help.
Thanks!
Matt
Old 09-30-2005, 07:22 PM
NOVA71's Avatar
NOVA71 NOVA71 is offline
The avenger carb has vaccuum secondaries correct? It sounds like the secondaries are opening up too fast. Pick up a spring kit for the secondaries and replace the spring with a stiffer one. This should hopefully fix your problem.
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 10-01-2005, 12:39 AM
I have to press the pedal slightly and then mash it in order for it not to bog. It makes sense since it's opening up the secondaries when I slightly press the pedal.
I checked out Holley's website and in their online manual they talk about a black spring that increases fuel economy and a yellow spring that increases performance.
Thanks!
Old 10-01-2005, 06:18 AM
NOVA71's Avatar
Yes, try the black one (stiffest) first. If that fixes the prob, you can work your way back with lighter springs until it bogs again and then go back to the lightest spring used before it started bogging. Let us know how it turns out.
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 10-05-2005, 01:47 PM
Hey that worked! Thanks for the help!!!
Old 10-06-2005, 04:43 AM
NOVA71's Avatar
Always nice when it's an easy fix!
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
