Old 09-30-2005, 10:05 AM
stevezaj stevezaj is offline
raising and lowering front & rear suspensions
What is best and easiest ways to do this? For a newbie!
Old 09-30-2005, 10:10 AM
freakray freakray is offline
AF Modelrater
Re: raising and lowering front & rear suspensions
Search, search, search.
FAQ and How to too.
AF User Guidelines
Old 09-30-2005, 10:59 AM
Vric's Avatar
Vric Vric is offline
ScaleWiki is your friend
Lower the ride height
Old 09-30-2005, 03:21 PM
Zlaja_'s Avatar
Zlaja_ Zlaja_ is offline
Send a message via MSN to Zlaja_
that must be the most complicated tutorial ever! I dont understand half of what he is talking about.
Old 09-30-2005, 03:46 PM
Vric's Avatar
Re: Re: raising and lowering front & rear suspensions
Well, just with the drawing, you should get the point.
Old 09-30-2005, 04:04 PM
AF Modelrater
I agree with Eric, and even so, there are plenty of threads on this topic that will come up with a forum search, each will contain more than one way to approach the task.
AF User Guidelines
Old 09-30-2005, 04:09 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Ray's got it. Every lowering job has its own approach. Try the search to find a more exact answer.
-Mike
Old 09-30-2005, 04:15 PM
Zlaja_'s Avatar
gah i must be retarded then!
Old 10-01-2005, 09:26 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
There are no really easy ways of doing it. It certainly can be done, but to do it well requires some scratchbuilding skills. It can be a very frustrating thing to try on your first or second build (or even fifth).
PHOTOBUCKET SUCKS
Old 10-01-2005, 10:18 AM
americanmuscleman americanmuscleman is offline
Send a message via AIM to americanmuscleman
lol theres one easy way iv used before. take a drill bit about the size of the stem that the tires go on then drill out a whole a little lower then the middle of the tire and put the stem in that, u can make it higher or lower
Old 10-01-2005, 10:47 AM
AF Modelrater
1. This only works on most Revell and AMT kits.
2. You'd probably find it better to drill the hole in the rim as opposed to the tire.
AF User Guidelines
Old 10-01-2005, 06:26 PM
Zlaja_'s Avatar
Old 10-01-2005, 09:58 PM
no u drill it in the piece that goes on the stem, iv done it once and it worked pretty good
