Go Back   Automotive Forums Car Chat > Chrysler > 300M
Old 09-29-2005, 06:50 PM
gusm1 gusm1 is offline
Question Timing belt failure
Own a 2000, 300M Chrysler with 4.6 liter engine. Timing belt failed. Is it normal for belt tensioners to fail as well or for valves to crash into pistons? Looking for second opinion before dishing out $2000.Total mileage: 80000 miles.
Old 09-29-2005, 10:06 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Timing belt failure
Are you sure you have a 4.6? The 300M only comes w/ the 3.5 V6. Anyway, the timing belt on that engine is supposed to be replaced at 105,000 mile intervals so you belt went premature. The tensioners don't usually fail causing the belt to jump time and cause interference between valves & pistons. I'd be willing to bet that you had either an oil leak or coolant leaking onto the belt causing it to break b/c it weakened the belt.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-02-2005, 10:27 AM
Mr. Javidogg Mr. Javidogg is offline
That sounds about right to me.
4.6??
"Javi's 03 Special M"
