Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-29-2005, 06:40 PM
sickcivic05 sickcivic05 is offline
Exclamation Headlights Wont Work
ok i have a 2000 civic ex coupe i have stage 2 nokya lights which are 90/100 ive had them for 3 months one side burnt out high and low beam now i only have high beam on one side if i put the low beams on the both turn on very dim and im not sure why i think they heat up so much they melt the stock clips i checked all the fuses they are fine what could it be???????? thanks
Old 09-29-2005, 08:54 PM
Copytech99 Copytech99 is offline
Re: Headlights Wont Work
Most likely the sockets are melting (almost double the rated wattage) I would look at them first. The wiring info can be found online at most libraries via Alldata or A R R C.
I would go back to stock bulbs.
