Old 09-29-2005, 05:57 PM
Maxpen Maxpen is offline
Question 4 Wheel alignment
Under normal circumstances, is 4 wheel alignment necessary or even desirable on a 02' T&C, or is it just another cash cow for mechanics? The manual does not mention it but when talking with a mechanic, whom we aren't familiar with as having just moved to this area, he suggested it be done, for only $20 more of course.
Any help will be appreciated.
Thanks.
Old 09-29-2005, 06:35 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 4 Wheel alignment
On a front drive vehicle the four wheel alignment is a good idea. It will help to reduce wear on the tires and make the vehicle drive better. They are not required each time you have one aligned but they are worth the money if the van hasn't been lined up in a while.
Old 09-29-2005, 06:52 PM
Thanks for the guidance. Since the 4 wheel alignment hasn't been done as yet we will have it taken care of.
Thanks again........
Old 09-29-2005, 07:36 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
alot of times, a car won't take a 4 wheel alignment
like in the case of my car. a 99 caravan with FWD, the rear wheels can't be adjusted because it doesn't have independant suspension
Old 09-30-2005, 10:53 AM
neon_rt's Avatar
neon_rt neon_rt is offline
They adjust the rear alignment by loosening the hubs (4 bolts) and inserting shims.
Old 09-30-2005, 12:17 PM
4 Wheel alignment
Thank you all for the info.
I will now be able to ask how 4 wheel alignment is done on vehicles like ours, without rear independent suspension, and see what answer I get. Credibility check time for the mechanic.
