Go Back   Automotive Forums Car Chat > BMW > X5
Old 09-29-2005, 05:38 PM
beerkat beerkat is offline
OBD II Codes.
I have a '01 X5. I am trying to find out more information on the codes. I threw two recently. P0491 & P0492 Secondary Air bank one and bank two. Any help would be great or where I can find out more about the codes.
Love to find a shop manual on the car also.
Old 10-14-2005, 02:35 PM
BAVARIANM BAVARIANM is offline
Those two faults are almost always the air pump. The diverter valve should be changed at the same time
Old 02-15-2006, 03:47 PM
Re: OBD II Codes.
Sorry it took me so long to get back here. So I need to replace the air pump and the diverter valve. Would you know the warranty information on this off hand?
Thank you for your help.
Old 02-15-2006, 07:35 PM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
Re: OBD II Codes.
It should be covered under new vehicle warranty, also if you have CPO it might possibly be covered. Other then that I believe the pump is around 300$ and the valve is something like 100$
Old 02-16-2006, 10:41 AM
xtreme barton xtreme barton is offline
Re: OBD II Codes.
The computer does not see a change in the o2 readings when it turns the airpump on to test it.
Possible problems are a bad air pump (full of water?),a bad airpump relay, a bad check valve, a bad vac control solenoid that supplies vac to the air control valve,a vac hose problem, or a bad solenoid itself.
The airpump is located in the right front of the engine compartment.It should run when the engine is first started cold.
If you dont know how to check the system from this info then you will need to have your mechanic have a look.
Old 03-08-2006, 11:43 AM
Re: OBD II Codes.
Thanks for all the help I plan on looking at it today. I do wish BMW sold their shop manuals.
Old 03-13-2006, 07:48 AM
Re: OBD II Codes.
Thanks to all of your help I have fixed my car. I found a vacuum line that had broken. Clipped off the bad end and plug it back on the solenoid an d the check engine light has not come on for several days now.
