Old 09-29-2005, 04:48 PM
panducci panducci is offline
Abs
My ABS light recently started coming on and going back off again. This is in conjunction with the brakes acting wonky. By wonky I mean that the car feels as if it is sliding when I brake, (sometimes). It makes the noise as if the ABS kicks in and feels like a rock on the pedal and then it will click down and the brake pedal goes the rest of the way down. My mechanic looked at it the other day but he didn't find what was going wrong. Any ideas would be greatly appreciated. I am not a mechanic nor do I know a lot of the terminology but I can pass the advice on to my mechanic. Thanks.
Old 09-29-2005, 05:00 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Abs
Most likely you have a WSS dropping out during low speeds...because of this, the ABS module thinks the wheel is sliding and initiates an ABS event.
I would check for codes and check the resistance of the WSS and for AC voltage output.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-29-2005, 05:29 PM
blazee's Avatar
blazee blazee is offline
Problem?
Here's a little more info on the condition that GMMMerlin is talking about. Just click the thumbs for the larger image.
Old 09-29-2005, 11:25 PM
JA no Y's Avatar
JA no Y JA no Y is offline
Also just check to make sure there is no debri between the sensor and the wheel assembly. Sometimes the sensor will attract some rusted metal, or metal shavings or some dirt can get caught inbetween the sensor and wheel assembly and play havoc with the sensor. I used some strips of a rag and wetted them down with some break cleaner and placed them on the wheel assembly. Then I turned the wheel assmebly so the rag went under the sensor to clear out any debri.
Old 09-30-2005, 06:09 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Blazee you have access to a lot of the tech stuff ha? Pretty cool! GMMERLIN that is a great quote!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-30-2005, 06:51 PM
GMMerlin's Avatar
I know stuff
Re: Abs
Thanks..I have the same info( and probally some additional ) but some of this information is pritory and releasing it could get me in trouble.
GM WCT
PM Me for details
Old 09-30-2005, 07:21 PM
blazee's Avatar
Problem?
Re: Abs
Yeah, I've got access to quite a bit of stuff, but GMMerlin's got access to stuff that we could only dream about.
Old 10-01-2005, 10:51 AM
GMMerlin's Avatar
I know stuff
Re: Re: Abs
Oh if you only knew
GM WCT
PM Me for details
Old 10-03-2005, 06:42 AM
blu88notch's Avatar
blu88notch blu88notch is offline
Question
I am also getting a low speed ABS activation, however it is only during low speed RIGHT hand turns, whether I am applying the brakes or just coasting. Frequently the ABS light will come on after that and it will not happen again until after the system resets itself and the light goes off.
Is there a way to deactivate the ABS system without affecting any other vehicle systems?
Thanks.
Old 10-04-2005, 10:57 AM
[RIT]IVIr_Evil's Avatar
[RIT]IVIr_Evil [RIT]IVIr_Evil is offline
Send a message via AIM to [RIT]IVIr_Evil Send a message via MSN to [RIT]IVIr_Evil
Re: Abs
Aslo have the same problem however my front drivers side brake is sticking, could the cause the activation at low speeds, since the brake is sticking causing the tire to go a a lower speed then the other, and the truck thinking it is sliding. If so should I just replace the caliper or just the VSS?
Old 10-27-2005, 03:01 PM
danfman danfman is offline
Re: Abs
Thanks.
Simple, pull the fuse.
Old 10-28-2005, 02:01 AM
nalgman's Avatar
nalgman nalgman is offline
Re: Abs
Thanks.
check this link...i had the same problem.. and i found a solution..
i dont know what year are you truck, but here it ishttp://www.automotiveforums.com/vbul...d.php?t=450651
Old 10-28-2005, 04:23 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: Abs
I need to work on my Abs too. Too much beer has hidden them in the tool shed . HAHA LOL . Rob
