| Off-Topic Talk about anything other than cars. |
Holy crap.... This problem wont go away... i refuse to think that a $50 altenator belt is really going to make a diffence in my screeching problem, i have tried two different belts, techinically three, previous owner had some weird shit belt on it, Someone suggested i buy the poly cog belt for the altenator, it worked, for 2 days, then BOOM screeching started..... its werid though, only when its cold outside it screeches. So, there is NAPA belt, and POLY COG from advanced that didn't work, the nearest dealership for chrysler told me i should call MITSU. The mitsu guy that is 20 miles away told me that it would be 1-2 week wait for the belt... and $44.69+ tax for the belt... so i called the second closest chrysler dealership which is 22 miles away..... He told me that it would take one week, and it would cost $48.44 + tax......... I seriously think it has to be something other than the belt..... but what? there is belt shavings everywhere, and i dont see anything grinding or dragging on the belt when running...... nothing like starting my car at school next to a 240SX with a front mount on it screeching like a son of a bitch.... I dont even want to try the dressing crap, becuase all i read is that it sucks.... and doesn't do anything.
STATUS: Near completion for the Engine PROJECT BEST 1G IN IL:70% Done MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n. Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Re: Will it end?
are the pulleys lined up perfectly? if you have belt shavings everywhere, obviously there is a problem.
Re: Will it end?
How can you tell if they are lined up perfectly? do i have to take everything apart? the engine and tranny were just rebuilt.... so i would asume so...
Re: Will it end?
alot of people have this problem with the belt sounds. Its a common problem with these cars, more on 2 g i thought but i could be wrong there
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
Re: Will it end?
well if that is the case? whats the fix?
Re: Will it end?
Buy som Belt Dressing from the local hardware store and spray it on the belt, the screeching will go away. Screeching is usually caused by the belt being too loose or too dry. Try tightning the pully tensioner the belt is on.
Re: Will it end?
I thought you were not suppose to put belt dressing on serpentine belts?
Matter in fact i believe it says that on the can, not recommended
Re: Will it end?
yah your not supposed to........ and belive me i have tried to tighten it and loosen it... doesn't change the ton of the screech...... i mean... for the person that made the comment that the pulleys might be not aligned right.... i just cant see someone who is rebuilding the engine making that huge of a mistake...
Re: Will it end?
anyone have any ideas?
Re: Re: Will it end?
Stock 2g belts are serpentine correct?
I just bought a belt dressing can the other day but didn't spray the actual belt. Only sprayed the turners as they looked pretty dry/rusty. It somewhat helped the sound (after 5-10 minutes of loud squeeling.), went away for the rest of my drive home wednesday, they came back tonight on my way back from work. It was a pretty cold night though so I don't know if that had something to do with it. But it was louder than previously when I never sprayed anything on it.
My ride: 1998 Eagle Talon TSI AWD - Standard
Re: Will it end?
is the pulley on the alternator moving ok when you start up the car?? or does it hesitate to start moving??
Re: Will it end?
DO NOT USE BELT DRESSING!!! it doesn't work for shit, just makes it worse in the long run.
you should just be able to look down the belt with your eye and see if the tensioners are lined up. the ONLY time belts squeal is if there is too much or too little tension, or there is a fluid on the belt. on one of my cars (420a motor) i spilt some anitfreeze on the serpentine belt and the belt squeeled like crazy for about 5-10 minutes and then i cleaned the belt and it squealed for a little bit but went away, so either your problem is too tight or too loose or something is dripping/running onto the belt. |
That is a fact. I just went through the Goodyear training course on belts at work, and they say belt companies love for you to use that crap. The belts wear out faster when you use it and you buy more belts. I wouldn't spray it anywhere near a belt. Which side of the belt is worn? They always ride to the side with the least amount of tension. How many miles are on the pulley? Also, if you can't tell by looking, try a string line to see if the pulleys are lined up correctly.
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
Without a doubt there's something out of alignment. Put on a belt, start the car and watch to see where it is out of alignment. With the belt off, check to see if everything spins freely. Might be the clutch on the a/c or the bearings in the alt.
1995 Jeep Wrangler 3 1/2" lift 33x12.50 tires 4.5L stroked I-6 Bored throttle body & Cold Air Intake Jet Chip Stage 2 Jet Thermostat Colorado Off Road Rig!!! |
