Old 09-29-2005, 02:54 PM
SKMoreloc SKMoreloc is offline
Thumbs up Ignition coil assembly
I have a 96 Pontiac GrandAm Se 2.4 /4 cylinder DOHC quad 4 motor. I was told the ignition coil assembly was bad on my car, so I bought the part from the auto parts store to replace it. Unfortunately, the part I received from the store was in pieces. None of the books I have on my car tell me how to assemble all the parts underneath the camshaft cover. Could someone send me some information on this.
Old 09-30-2005, 08:12 AM
ctesla's Avatar
ctesla ctesla is offline
Susan,
welcome to AF.
you shouldn't need any pics, as after you remove your cam cover (I think four 10mm bolts) and unplug the coil connector, you will have a complete blueprint in front of you.
a large white plastic shield is clipped to the underside of the cover, and I believe four black elongated boots clamp to the main cover to drop into the wells to attech to the spark plug tips.
under the large white housing, lies the coil pack (and also I think the control module?) which will be held by I am pretty sure 5.5mm bolts.
just remove and replace in reverse order.
hope this helps,
chris
nrt racing
Old 09-30-2005, 08:58 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
The control module is under the cover on the 2.4's, when you flip the cover over pay attention to where everything is under the white plastic cover, and change one coil at a time, just pay attention to where the wiring goes. It's pretty easy to change the coils, there should only be 2 of them. Good luck.
