Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 09-29-2005, 02:36 PM
steve420 steve420 is offline
anyone have pics of x with 31 and or 32 with stock lift
im wanting to go bigger in tire size. i know i could put a 265 75 r16 on the x with just torsion adjustments. the 265 70 r16 requires no adjustment but i dont want it to be to small either. most pics you find are with 3" lifts which im to broke to get right now.
Old 09-29-2005, 03:31 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: anyone have pics of x with 31 and or 32 with stock lift
32" tires with no suspension lift:
When did you last check your spare tire's pressure?
Old 09-29-2005, 04:16 PM
that looks awsome. so it looks like you didnt even mess with the torsion bar. is that true. did you have alot of rub or did you trim the usual places and havnt had a problem since. nice x
Old 09-29-2005, 05:20 PM
You'll find what's needed to fit various tires well documented in the Tire/Wheel and/or Suspension sections. I just trimmed.
Old 10-19-2005, 08:21 PM
does it rubb at all. Did you leave your torsion bars at stock adjustments?
Old 10-20-2005, 09:16 AM
I trimmed to fix the flare/flap rubbing. T-bars are at stock adjustment. There is some rubbing by the top of the tire on the inner fender liner behind the headlight area at max compression, but it's harmless. Mine rubbed through, it's just dead air behind it.
Old 11-10-2005, 08:35 AM
cooleyvette cooleyvette is offline
Re: Re: anyone have pics of x with 31 and or 32 with stock lift
did mine about a week ago. put bfg a/t ko 265 75 16 and took the lower piece of the front mudflap (5 bolts) then cut that lip off with a box cutter and wall la no more rubbing, better gas milage, smoother ride looks better, sits noticably higher and is a bad boy off road. best money ever spent on a vehicle.
