Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 09-29-2005, 02:34 PM
Rob31803 Rob31803 is offline
2001 Battery Drain
Can anyone tell me how to diagnose a battery drain on a 2001? If it sits up a couple of days, the battery runs down to the point of not starting. Any help would be appreciated.
Old 12-04-2005, 09:50 AM
jrm14 jrm14 is offline
Re: 2001 Battery Drain
Rob- I have the same problem. I see nobody answered, did you ever find the answer some other way. A friend of mine vaguely remembers something about an adaptor to buy that cures it which he is pursuing. If it's not solved for you now, I'll keep you posted. Hopefully you have the answer already. Thanks, Jack
Old 12-10-2005, 07:40 AM
mga mga is offline
Re: Re: 2001 Battery Drain
disconnect the negative cable and use a 12 volt test light between that and the battery. it should glow.
while this is hooked up, begin pulling fuses ONE AT A TIME and REPLACE each after pulling them. the circuit that is draining the battery will shut the test light OFF. this gives you an idea which circuit is draining your battery and where to look for any shorts.
if the light does not go out after pulling fuses, next is to unplug things like the alternator, etc etc... i've done this on my '81 vette with excellent results.
using this method i have found many problems with people's cars, including a bad alternator on a ford truck.
Old 12-11-2005, 06:41 AM
Re: Re: Re: 2001 Battery Drain
Thank you very much, worth a try.
Old 12-13-2005, 04:08 PM
WEF WEF is offline
The battery will normally have a drain of about 50 milliamperes to run the electronics. Be sure your battery is OK, a weak cell could cause this. If it's the original battery, I'd replace it without bothering to test it.
Old 04-16-2006, 03:44 AM
Bernard Feltzer Bernard Feltzer is offline
Had the exact same problem.
Dealers thought it was a batch of bad starters.
It wasn't, it was the cable that goes to starter.
Starter is exposed to plenty of heat because it is right next to Cat converter, which has to be removed to change starter.
Cable harness was shorted.
GM covered all expenses and supplied another new battery, also the tow truck bill.
Had the extended warranty.
