Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 09-29-2005, 02:06 PM
kathy18 kathy18 is offline
Unhappy my nissan sentra wont start help
i have change my spark plugs wires cap and rotor and now my car wont start i have tried everything mechanics tell me that i am not getting no fire can it be my timing chain? someone please help
Old 09-29-2005, 02:15 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: my nissan sentra wont start help
did u check oil/coolant levels? how about the battery?
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 09-29-2005, 02:20 PM
I have plenty of coolant the battery is fine and i have plenty of oil its not that people are telling me it might be timing chains could that be the problem
Old 09-29-2005, 02:51 PM
botang botang is offline
What year is your car? My nissan sentra is 94 and a nissan mechanics told me this car does not use any timing belt anymore and the model has be changed to other mechanical way. So if your car is 94 or later you should not worry about the timing belt.
Old 09-29-2005, 11:33 PM
slideways...'s Avatar
slideways... slideways... is offline
botang-it uses a timing chain
chains last longer, but are prone to stretching over time, which can throw off the timing. but that wouldnt cause no spark. i hate to give bad news, but it sounds like its your distributor. (could be the coil, but if i recall, the coil is inside the distributor and possibly not replaceable by itself, check with a parts store or dealer to see for sure). worst case is bad ecu.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 09-30-2005, 07:43 AM
Re: Re: my nissan sentra wont start help
my car is 1991 so i am not sure what is going on with the car guess i willhave to put on a computer to find out what is the problem. But I am still hoping someone can tell me something that will help try since we have looked at everything else. People are telling me its not getting a good connection from the coil to the cap. So still trying to figure it out.
Old 09-30-2005, 08:34 AM
that is not the cap is it? the part where all the wires go in. Cause if so i changed that. What is the ecu?
Old 10-01-2005, 02:37 AM
no the distributor is the part the cap bolts to. the ecu is the engine computer, located inside the car(not under hood)
