displacment question
What would 40 over on a chevy 350 be? I was thinking like 357 c.i.d. I'm not sure.
89 iroc tired tpi 305, 700r-4 and 2.73 posi rearend soon to be my LITTLE RED NIGHTMARE!!!!! (in storage) 99 grand prix silver 3.8 loaded (daily driver with 190,500 miles and going like a top!) POOR COLLEGE STUDENT!!!!!!!!!!!!!!! |
Re: displacment question
Bore x Bore x Stroke x (pi x 2) = Engine Displacement 4.04 x 4.04 x 3.48 x (pi x 2) ≈ 356.88 So yes, you would call it a 357.
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson |
Thanks
that would be cool....a little different....however would that be cutting the cylinder walls to thin? Cutting into water jacket thin?
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Not a problem. I have a 350 bored .040 over with a 400 crank in mine. 384.7 ci. Or 385. (.030 plus a 400 crank is a 383...) - Mark
The correct equation, in case you were wondering is as follows:
Bore * Bore * Stroke * .785 * # of cylinders I have no idea how 2PI fits in? Is that a standard for just V8's? Anyways, the above is the standard equation. /edit: With that above equation, how do you calculate the Cubic Inches for a V6? Or what if you want to calculate the displacement for 1 cylinder? I dont think that equation is right, not at all, its even off by 2 tenths of a cubic inch for a V8.
The 2PI thing is basicly the .785*8.
If you want a quick calculator.... http://www.c5frc.com/calculators/Com...Calculator.htm Just use half of the calculator. The bore and stroke to displacement part.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
Yeah, I figured it had to be something like that. Kind of dumb if you ask me, because you arent able to find the displacement per cylinder, for a different size engine, plus it was 2 tenths of a cubic inch off =P
Re: Re: displacment question
Area of a cylinder: pi(r^2) x h, where r is the radius, and h is the height of the cylinder. Now, bore = diameter, and stroke = height. Half the diameter is the radius. Bore is 4.04, so the radius is 2.02, and the stroke is 3.48 pi(2.02^2)(3.48) = 44.609962229....that is the displacement of one cylinder. Multiply by 8, 356.87969783....so we'll call it a 357. Plug the numbers into the table on the link that Luos left, what do you get? The displacement is rounded to 356.88.
Thats all well and good, but the equation you just gave me is not the same as the one you gave me the first time, you might get the same answer, but it doesnt follow the same logic.
The second equation might give you the answer, but your doing way more steps then you need to. And theres no need to be a smart ass, because the equation that the makers of pistons and various internal engine parts gives you, is: Bore * Bore * Stroke * .785 * # of cylinders. Thats the standard equation.
Edit: Took out some unpleasantness.
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson Last edited by ct91rs; 09-30-2005 at 09:22 PM. |
