Old 09-29-2005, 12:53 PM
mark spencer mark spencer is offline
Unhappy help urgent oil pan needs removing
help wife hit a metal object i now have a hole in the oil pan tray i have removed all the screw (i think) still wont come away
Old 09-30-2005, 08:26 AM
RatLabGuy's Avatar
RatLabGuy RatLabGuy is offline
Send a message via AIM to RatLabGuy
Re: help urgent oil pan needs removing
Then you must not have all teh screws out...
Mine I had to take a rubber mallet and whack it from the side a few times to break the seal, esp if its been on there a long time. Get ready for a mess when it falls too, lol.
Old 09-30-2005, 09:32 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
kick it.
Old 10-02-2005, 08:32 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
I fixed an oil pan once with JB Weld. Never leaked.
Nevada Tumbleweed
Old 10-04-2005, 08:50 AM
Lynde Lynde is offline
You will have to drop down the exhaust pipe, you will never get it out if you don't. Make sure you have removed the two bolts going parrellel with the transmission. (13 mm ?) Now you will have to strike the pan with a rubber mallet or use a block of wood w/ a hammer, and try and break loose the silicone seal. You can also try prying down with a pry bar to "pop" it loose. Make sure your careful about cleaning the silicone off the block. Using some brake cleaner might help, Good Luck
