Old 09-29-2005, 12:51 PM
dk05 dk05 is offline
Which sensor?
Hmm... well I changed the Coolant Temperature Sensor in my 85 IROC (305 TPI H.O.) today but the dash gauge still does not work..? I guess that is not the right sensor, heh. Does anyone know what sensor it is for the gauge on the dash? Where is the sensor located? Thanks a ton.
Old 09-29-2005, 01:42 PM
ct91rs ct91rs is offline
Re: Which sensor?
The sensor you want to change is in the block between cylinders 1 & 3 (driver's side).
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson
Old 09-29-2005, 09:39 PM
Morley Morley is offline
The one you changed is the coolant temp sensor...sensors feed the ECM..what you want to change is the sender...senders feed the gauges.
Old 09-30-2005, 01:32 AM
Thanks. Does anyone happen to know the GM part number for the 85 sensor? I can't seem to find it anywhere.
Old 10-01-2005, 08:10 PM
daman daman is offline
Before you buy a sensor,check your cluster, ground the wire to the sensor and the gauge should max out.
try here, http://www.gmpartsdirect.com/partsvoice/frameset.cfm
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 10-02-2005, 05:36 AM
Only problem with that is I cannot seem to find the sensor anywhere. The only wires going to the engine block on either side are for the spark plugs. It does look like there is a screw in plug in a hole in between the #1 and #3 plugs though, but still there is no wire leading to anywhere around that area.
Old 10-02-2005, 08:17 AM
Re: Which sensor?
There is another switch between the #6 & #8 cylinders on the passanger side. Take the wire off. Does it have a single small threaded terminal, or a spade terminal that the wire connects too?
You could check the gauge in the dash, but it's a bit of a pain to get at, and alot less likely to be the cause of your problem.
Old 10-02-2005, 04:05 PM
The one on the passenger side is the knock sensor I thought? Either way there is no wire going to it whatever it is. The guy I bought the car from swapped motors on it but I am guessing did not hook everything up correctly..? He has some sort of plug with a green and brown wire just hanging above the engine with a resistor jammed in it. Have no clue what that is for either.
Old 10-02-2005, 05:12 PM
Re: Which sensor?
The plug you are refering to is probably for the IAT (intake air temperature) sensor. It sounds like he put a resistor in-line to bypass the IAT sensor, making the ecm think the incoming air is very cold, thus enriching the air/fuel mixture. This is supposed to "boost" your power, but in my opinion it is just wasting fuel.
Originally your engine would have had a switch on the passenger side where I described. It is behind and a bit above the knock sensor. This switch was used to turn on the cooling fan(s). The sender on the driver's side is for the gauge in the dash. I would venture a guess here that your gauge hasn't worked since you bought the car?
Old 10-02-2005, 05:35 PM
That's correct, it hasn't but the cooling fan is always on. I think also he may have removed the thermostat but i'm not sure. I thought the IAT sensor was on the throttle body? There is no way that plug could even reach the throttle body. Not to say that it is not the IAT though. Could maybe explain why it keeps choking off when it is cold outside..... The odd thing about the gauge is that it sort of moves a little then just sits on the bottom. If there is no sensor hooked up I would assume that there is no way for it to move though. Only thing is that you guys and my chiltons both say that the engine temp sensor is supposed to be by #1 and #3 but like I said there is no wires at all on either side that even go close to the heads. I am very confused...
Old 10-02-2005, 07:26 PM
Re: Which sensor?
The IAT sensor is threaded into the underside of the plenum, probably a foot behind the throttle body. If the fans run all the time (i.e. whenever the car is running), he most likely bypassed the switch and has them running off the ignition(hopefully with a relay).
If you want the gauge to work, you will need to replace the plug with the temp sending unit, and find the wire that goes to the gauge. It will be coming through the firewall on the drivers side, behind, and to the right of the master cylinder. There are two main clusters. It is located in the cluster closest to the fender. On my '91 it is a thin, fairly dark green wire. I'll try to varify that you are looking for the same color wire tomorrow.
Old 10-02-2005, 11:43 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Which sensor?
in the wiring warness of the engine's left side you should find a green wire, that is the wire for the sending unit lacoted squarly between 1 and 3 as mentioned.
Old 10-03-2005, 12:51 PM
Thanks, I'll have to look for that and post back if I can find it or not.
Old 10-05-2005, 07:43 PM
wrightz28's Avatar
Re: Which sensor?
it usually shares a breakout with the o2 sensor wire from the main harness
