Old 09-29-2005, 07:57 AM
nuggetray nuggetray is offline
Send a message via MSN to nuggetray
99 ford escort dies when it gets hot,no check engine light on.
when the escort gets hot it starts to die its a 99 ford escort 2.0, we just changed the head ,injectors,radiator, about 10.000 miles ago, it started about 3000 miles ago any help will be greatly appreciated.
Old 10-04-2005, 10:01 PM
Lynde Lynde is offline
Re: 99 ford escort dies when it gets hot,no check engine light on.
Try changing the Idle air control valve. and cleaning the carbon out of the throttle body. Also look for a broken vacuum hose going to or from the intake. Exsp. the pcv valve and hose might be collapsed. Also perform a fuel pressure test, your pump may be failing.
