Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 09-29-2005, 07:44 AM
dennisthemenace dennisthemenace is offline
1994 Chrysler LHS New Starter
Problem started after Chrysler dealer fixed re-call notice on shift lever. When the iginition key is turned I get a clinking noise. I sometimes have to turn the key several times before the car will start.
At first I thought not enough juice was getting to the starter so I cleaned off the battery terminal and the problem still exists.
Can someone please tell me the best way to install a new starter? Does the crossmember have to be removed? Thanks for your help!
Old 09-29-2005, 10:55 PM
Aces0vr8s's Avatar
Aces0vr8s Aces0vr8s is offline
Send a message via AIM to Aces0vr8s Send a message via Yahoo to Aces0vr8s
Re: 1994 Chrysler LHS New Starter
hey umm motorcycle forem lol id tell you what could be wrong but your in the wrong forem so i wont
Old 09-29-2005, 11:05 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
If all you hear is a "click" unfortunately your starter solenoid is going bad on you and you'll need to remove the starter just to fix it. The starter should be mounted on the driver's side mounted on the transmission w/ 3 bolts holding it in place. On some models, it comes with an aluminum heat shield so you might have to remove that if you have that heat shield.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-04-2005, 09:09 AM
Re: Re: 1994 Chrysler LHS New Starter
Sorry about that-will move it out of this forum
