Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 05-15-2002, 05:06 PM
marjon marjon is offline
Angry Nissan Pickup Truck Trouble
I have a 1984 Nissan Pickup that starts ok but sometimes when I let off the clutch and start to move it kills and won't start again for 10 min. to an hour. Sometimes it won't start at all, so I have it towed to a mechanic. As soon as the mechanic gets it, it starts with no problem.
This is a 1984 Nissan Pickup Model NL-Stuf, Z24 2389cc Engine,
5 speed transmission and carburator fuel system.
Does anyone know what causes this problem?
I need help!
Thanks
Old 08-17-2002, 06:18 PM
missinglink missinglink is offline
Question 1984 Nissan King Cab
My 1984 Nissan King Cab will not restart sometimes after the engine is warm. I've replaced the fuel filter and fuel pump. Next I'll replace the fuel pump relay under the glovebox on the right side.
Any other suggestions?
missinglink
Old 09-19-2002, 10:51 PM
Jacobby Jacobby is offline
older datsun/nissan truck
Remember that on 'some' of the trucks there is a fule filter "hidden" on the passenger side. This filter can be inside a black cloth bag stuffed up by the frame.
Follow the gas line from the tank forward feeling it.
This filter was hidden and stumped a few mechanics. If clogged the engine will run then choke down.
Also on carburetor models there can be a fuel 'strainer' screen inside the carburetor at the end of the fuel line.
Old 10-02-2002, 09:16 PM
Arcadian Arcadian is offline
Yeah the filter on the passenger side right under the gas port, you should check that its clogs up alot..
Change that often if you have bad gas in your nieghborhood.. because gas filters nowadays goes bad faster since they are catching alot more dirt..
Take care
Arcadian
Old 02-04-2003, 12:09 AM
MaximaSEAE01's Avatar
MaximaSEAE01 MaximaSEAE01 is offline
Send a message via AIM to MaximaSEAE01
what about the O2 sensors? i had idling problems and hardtime starting after engine got warm. any relevance?
SHIFT_VQ35 SWAP
Old 10-08-2003, 07:20 PM
Candlemaker Candlemaker is offline
truck trouble
my 85 did the same try the stinkin ignition relay it frys really
