Old 09-28-2005, 10:53 PM
Rugerlab's Avatar
Rugerlab Rugerlab is offline
Send a message via ICQ to Rugerlab
Alternator Question?
Hello all, I have been reading this forum for a while now and finally decided to post something. Truck wouldn't start tonight just made a clicking noise when i turned it over. Starter sounds like its working. I thought it was the battery cause when i looked at the positive terminal it was leaking so got a new optima and put it in tonight and still nothin. So alternator.... how do i figure out what alternator i have? Its a 99 chevy ls z71 with a 5.3. any help would be great and if you need more info let me know. Thanks Eric
Old 09-28-2005, 10:59 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Alternator Question?
probably just the standard 105 Amp
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 09-28-2005, 11:04 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Look on the casing there are numbers stamped into it. You'll more than likely find the "105" next ot the center line where the two halves meet....
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 09-28-2005, 11:10 PM
Rugerlab's Avatar
I can't find anything stamped into it. Would it be on the underside (the alternator is still installed in the truck) cause theres nothing on the parts i can see
Old 09-28-2005, 11:18 PM
jethro_3's Avatar
Real small pings in the shape of the letters, like 8 ping marks to make a straight line. Take a rag with cleaner to the casing, it's near the casing halves on top. Shine a light from the side it will show up better..... Climb in, the engine is calling you... Joke
Cam in and
Check out my Ride
Old 09-28-2005, 11:23 PM
Rugerlab's Avatar
ok after a cleaning i found this printed on it 10460229 and below that 6269A 12V N or something very close to that but still no 105 or 130? Does this mean anything
Old 09-29-2005, 02:32 AM
2000CAYukon 2000CAYukon is offline
Re: Re: Alternator Question?
www.acdelco.com lists that as a 105 AMP. Reman'd ac delco number is 321-1798.
//2000CAYukon
Old 09-29-2005, 03:16 AM
Tall Tall is offline
The alternator wont keep ur truck from starting.... unless the battery is dead. But since u dropped a new battery in, thats not ur problem.
Old 09-29-2005, 05:42 AM
jers99z jers99z is offline
Send a message via AIM to jers99z Send a message via MSN to jers99z Send a message via Yahoo to jers99z
Have you tried cleaning the ground and power cables that run from your battery to your starter. I had a problem with corrosion in one of my cables and my truck acted real messed up. It didnt want to stay running then, I just couldnt get it started anymore. Cleaned cables and tightened them good and the truck was good as new.
99 Z-71 5.3 liter. Jet stage 2, volant cool air intake, flowmaster 40 series, billet grill, clear corners, chrome bed rails, pioneer cd player, Infinity Kappa speakers, silverstars.http://www.cardomain.com/ride/2094079
Old 09-29-2005, 05:44 AM
oh one other thing, i went through 3 batteries trying to figure out what the hell was wrong. Everytime i would almost start the truck it would drain the battery, the truck wouldnt even start off a jump. I dont know if you are having symptoms like this but hey its a place to look.
Old 09-29-2005, 06:28 PM
Rugerlab's Avatar
Thanks to all that helped, got a new alternator today and everything is running great. Turned out the ac delco battery i had was natorious for leaking acid on the positive terminal. So stay away from those batterys. I had to replace the positive cable completely it was so coroded from the crappy battery. New optima battery and new alternator and about $375 down the drain and the truck runs like new again.
