I've recently run into a problem, see if this hits home with anyone, and if you have any ideas on what the problem is, please...share.
Whenever I get in to start my Amigo, it turns over...starts for half a second then cuts off, after doing this several times, I must push the gas all the way down and let it wind high and hard until it makes a sort of pop sound, like a backfire, then and only then will it stay cranked. This happens whenever the car needs to be cranked, even after having driven for a while. Dad changed the gas filter. Didn't change anything. He thinks it could be the injectors, but I had someone mention the TPS (throttle position sensor). That sounded good, but all the information I've read about the TPS mentions nothing about hard starts...only mentioning a rough ride and idle. Neither of which is a problem once I've started the car. Please, any help would be greatly appreciated, simply because cranking my car takes about 2-3 dollars in gas at a time...and we all know gas is getting out of hand $$ wise. THANX, Charity |
Re: Help Please!!!
seeing that you have a 91, your timing might be off?
maybe a new Cap and rotor? When was the last time you had a tune up?
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Re: Re: Help Please!!!
I'm having the same problem with my 99 amigo V6(50k). I actually was just looking for a solution to that problem, myself. When I try to start the vehicle, it will run for about 1.5 seconds, then shut off. The second time I try to start it, it almost seems that it is flooded with fuel because it is hard to start. Then when it does start, it sputters for a few seconds then straightens out. After that it runs fine...until the next time I try to start it. It just started to do this, and seems to be getting worse by the week. Any help would be greatly appreciated.
Re: Help Please!!!
the key things to look at and replace are:
the fuel filter (yours could be plugged) your fuel pressure regulator Or you have a leaky intake manifold gasket (very common). please see the FAQ link in my sig below for more info.
