Old 09-28-2005, 07:38 PM
Icebox's Avatar
Icebox Icebox is offline
Send a message via AIM to Icebox Send a message via Yahoo to Icebox
Exclamation need help quick!
We just bought a pair of APC projection headlights from this company off of ebay. Anyway, the question is...there are two adjustments for the headlights. One up and down, the other inward and outward. The inward, outward adjustment has a spring in it. These adjustments on also on the stock headlights (at least this is what i am told). We need to know how this adjustment works. We can't fingure it out and and if anyone as hand info on how they do it would be much appreciated. Thanks.
Christen
p.s it's really dark here in ny right now and we kinda need to go to the store and this is the only car on the road...lol
Old 10-02-2005, 01:01 PM
Igovert500's Avatar
blue + red light magnet
Re: need help quick!
Well I'm not sure if you mean you don't know how to get them properly aligned or if you mean you can't turn the screws. Generally I think a screwdriver works fine.
Anyway as far as alignment, this is a pretty detailed writeup:
http://www.danielsternlighting.com/tech/aim/aim.html
Or if you want to just do it a bit more simply, On level ground, put your vehicle in front of a wall as close as possible. With tape, put 4 crosses on the wall that correspond with the vertical and horizontal center lines of each headlight (low and high beams). Back up 25 ft., keeping the vehicle centered with your crosses on the wall. Turn on headlights. Low Beams should be hitting the lower right sections of the corresponding crosses. High Beams should split their corresponding cross hairs. Turn the horizonal and vertical adjusting screws (located at the headlights) to make adjustments.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-03-2005, 01:21 PM
Icebox's Avatar
thanks i'll post some pics for you to show you what i'm talking about
1990 Honda Prelude Si 2.1
My Baby....
