Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-28-2005, 06:20 PM
cory fincher cory fincher is offline
idle problem
hey its me again. i also am having issues with my idle. sometimes when i start my car (95 gst) it is fine the next time i will start it it idles at 2000 rpm. it is differant ever time i start the car. thanks for any help.
Old 10-03-2005, 07:32 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: idle problem
I had a similar problem on my 95 Tsi Talon, I changed the Throttle possision sensor, that wasn't it.Then the Manifold differential pressure sensor, also wasn't the problem. I took out the throttle body and it had carbon residue making the valve stick. So I used a tooth brush and a little bit of fuel injector cleaner to scrub the inside clean. When I had reassembled everything it was much better but would still start to raise it's idle when the engine got hot. I finally realized the obvious. After all that work all it took was a $1.50 spring from Canadian tire on the exterior of the throttle body, to assist closing the valve. This makes the gas pedal ultra touchy but I love it this way, as I find that it drops the RPM much quicker when shifting and makes the stock BOV a little louder. After three years of driving the car like this I haven't had a single problem. You should experiment with different spring tentions to find just the right one. Good luck.
Let me know if this helps.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 10-18-2005, 05:53 PM
Re: idle problem
So, did you solve your problem?
